Original Steamer Photos
Discussion in 'Steam Traction Engines' started by Ned, Nov 13, 2017.
  1. Ned
    This is about 1890s 20hp Case center crank. Center crank means the engine/cylinder was mounted in the center of the boiler instead of off to the side thus this engine has a flywheel on each side. Note the extravagant cast iron gear guard on the right side of the engine in the rear with that large gear guard the steering was is moved to the left side of the engine.
    Todd Hintz likes this.
  2. Ned
    I'm glad you like them!!! I'll keep posting as long as people want to see them or someone tells me to stop :Shrugs:
  3. Ned
    Not all my photos are steam traction engines I will post other things (i.e. trains, cranes, and gas tractors).
    This is the pride of the Soo Line the Mighty switch engine 353 working in the Duluth MN RR yard
    Tia Braseth and Todd Hintz like this.
  4. Ned
    Gas tractor time. This is an Avery 12-25hp pulling a couple sickle movers. This has to be a staged photo as all 3 men are in clean white shirts and vests I'm guess a shirt wouldn't stay white very long while riding on a sickle mower
  5. Ned
    This is a rare one this is a Bates 25hp gas tractor. From what I was told there's only like 3 of these complete and running
  6. Ned
    Return flue Avery not sure of the size probably in the 16-20hp range
  7. Mrs. Ned (Liz)
    Mrs. Ned (Liz) WMSTR Lifetime Members WMSTR Lifetime Member
    Thanks Doxey!
  8. Ned
    Here's another favorite. Even though it's a black and white photo you can see the shine on the flywheel on this Case and with a straw stack nearly as tall as the barn a dual wing feed separator one can only imagine the work this engine did that day. Also notice the dual whistles and a ear of corn hanging from the plumbing on the side of the engine. The pipe on the front of the smoke stack is a form of a spark arrestor
  9. craig mattson
    craig mattson Mega Poster WMSTR Lifetime Member
    Very cool picture Ned! Thanks for sharing
  10. DOXEY41
    Case center crank photo. The thing that sticks out to me is the guy's are smiling! Normally you don't ever see people smile in vintage photo's. Anyone agree?
    Ned likes this.
  11. Darren Gunderson
    Darren Gunderson 20 Minneapolis #8702 Crew WMSTR Lifetime Member
    Josh,
    Depending on the age of the photo, one reason that you don't see people smile as much is that the exposure times could be quite long. It was hard to hold a natural looking smile for several seconds and not have it look fake and goofy. Exposure times improved greatly towards the end of the 19th century and early 20th century, but it could still take much longer than what we are used to with a quick snap of the button. It was better if there were a lot of natural light.
    Of course it could just be that they were a bunch of grumpy farmers tired out from a long day of work.
    Darren
    Todd Hintz and Ned like this.
  12. M Kerkvliet
    Folks have a hard time getting me to smile in modern photos! Guess I'm not a smiler. I would have fit right in!
    Thanks Erik, Darren, and all involved for a very cool thread!
    Ned likes this.
  13. Ned
    Avery threshing crew. Notice the dual flywheel attachment for a belt to run up to the pulleys by the rear wheel then down to the buzz saw on the back of the engine. This is probably non OSHA compliant
  14. Ned
    This one always gets me. I'm not sure if the guys are brave, crazy, or stupid? I believe this is a 35hp Nichols and Shepard crossing a bridge. (engine weight over 45,000lbs)What do you think that bridge is rated for???
    You can just make out the threshing machine on the other side of the bridge. Sometimes farmers would unhook on one side of a bridge and pull the thresher across with a cable as most of the time the heaviest part of a steamer is the rear end and the heaviest part of a thresher is the front
    Tia Braseth likes this.
  15. Ned
    This is a Frick that tested the strength of a bridge at least the engine stayed upright doesn't look like the threshing machine faired as well. Ironically the location of the photo is Pleasant Gap Penn.
  16. Ned
    Huber not sure of the age or size of the engine. The men are holding banners that say Worlds Fair Contest Huber MFG
    Mike Bennett likes this.
  17. Ned
    Another Aver return flue
  18. Ned
    80hp Case threshing
  19. Ned
    Here's a Case portable boiler notice the lack of an engine no flywheel or cylinder
  20. Ned
    Buffalo Pitts return flue with straw burning attachment
